If say I use AS5048A magnetic encoder, to be able to find the angle at such high rpm, would it still be possible to use PWM? Or do I have to use the digital read? In that case, how would I program it?
Hello. My circuit board got broken and I need to get a new. This part can not longer be bought. It is a tachometer amplifier. It gets the signal from a tachometer sensor (counting the time the engine ...
I got some PCBs made from PCBway that have the JST PH female connectors on and they work great. I now need to find a somewhere that has a large selection of LEDs (including SMD LED) that either h...
It connects all the pads altogether even if there’s no connection between them by traces. This is an old project from version 3 opened in the new 4.0.5 version, these pads were unconnected before.
