I want to make an ESC for a 3-Phase BLDC motor using an arduino nano. I want to use the digital output pins to drive transistors that will in turn drive the MOSFETs for the motor. At 10,000 RPM each p...
Hi all, I was wondering if there is a way to remove the footprint and leave only the Drill pad, in the past I printed another circuit but the footprint outline actually made a connection which I had t...
I am trying to place a capacitor (right) next to an amplifier (left). But cannot move it closer than 0.25mm, although I set the horizontal component spacing to 0.0mm and pad to pad clearance is 0.15mm...
Hello I am interested in Steven-Mark TPU Driver Beta V1 pcb you are offering. Where can I get the components overlay diagram and circuit diagram for it?Kind RegardsMichael
I destroyed a clock radio to turn it into something else, and I used a different display that I already knew how to use. Now I'm trying to reuse the old display, and I've found the commons, bu...
