[PCB Assembly] pcb files...
I want to repeat this project. Can you provide PCB or Gerber files?
9answers
[Others] Soldering question: how to reliably solder thin stranded copper wires together?
I've been struggling with soldering some very small stranded copper wires together. The wires are very high gauge (seems like 26awg) and there's maybe only 10 or so thin strands. After strippi...
[Others] Is it s kind of connector?
It connects directly to gold fingers on PCB. Edge Connector? IDC?
[Others] How to prevent DIP pin from connecting to Vcc layer.
I have a 4 layer board with internal power layers. I'm trying to add a decoupling cap to a DIP IC. The problem I 'believe' I have is that the 10 Pin is set to Vcc net and Altium is c...
  • answered Sep 25,2020
[Others] Can the output voltage of an opamp damage the opamp if it is amplified to a level beyond either of the supply rails?
If I am making a differential amplifier (for example) with both input voltages within the limits - if the output signal is amplified beyond either of the rail voltages (<Vee or >Vcc) would this ...
[PCB Prototype] AaaaaAaaaaaaaaa
Sawtooth waveform convert to squre pulse
[Others] what's the name of these orange guys?
I was thinking they are ceramic capacitors, but the marking on the board is FL?
1 ... 97 98 99 100 101 102 103 104 105 106 107 ...
