[Others] Do MOSFETs rated for higher current typically have less heat dissipation?
I want to improve the current on one of my inverter circuits, but I don't have larger heat sinks. The current MOSFETs on there are rated for about 10 amps, but I have others that are rated for 50 ...
  • answered Aug 19,2020
[Others] Is there a way to rename power labels?
I am trying to implement a schottky diode (BAT54C) that takes in +5V from the USB connection and +5V from an external source and joins them so that current does not leak backwards into the USB port. I...
[Others] What’s the best way to send a python file from the raspberry pi 3 to raspberry pi 0 for use by the pi 0
I'm looking to share a file from the pi 3 that contains a password to the pi zero that has the key to decrypt. I was thinking about using MQTT or SSH but am unsure of the file sharing aspect. Addi...
  • answered Aug 18,2020
[Others] Could a H-Bridge work with 4 indentical transistors?
I'm curious if it's possible with inverting the input of two FETs? Or connecting the input of the high side FETs and low side FETs on the opposite side of the motor together,is it possible to ...
[Others] How do I wire the led to a power source
Hello, I bought led strip that I plan to connect to a power bank. The strip is rated at 5v and has 144 WS2812B leds. The both sides of the strip have 3 pin connectors and 2 wires for ground and power....
  • answered Aug 17,2020
[PCB Prototype] ORDER NUMBER: G578891
I have just placed an order for pcb's ORDER NUMBER:G578891I would like to add something to the same order so I can save on shipping and duties
[PCB Prototype] BOM of material
Thanks for your design,Please send me the components list ( BOM of material ).Best regardsGeorges
[PCB Prototype] question about the induction pcb
Dear Amis,Can i ask you something about the induction pcb?can you add me to whatsapp +31624827929KR,U. Ozdemir
