[Others] Rotary encoder keyboard for Hantek PC Scope
Can you please advise on schematic available for a keyboard contaning rotary encoders. This project is for a Hantek 6254 USB PC based Scope.
  • answered Aug 07,2020
    by Jason
[PCB Prototype] Confusion about GND and no net zones.
Hi, I've been designing a keyboard pcb, and I'm a bit confused about GND and no net zones, as in when I should use them( both layers, or just one? Also, should I have isolated copper fills at ...
    by Kemio
[PCB Prototype] Material used as a stiffener for FPC
I need part number of material or its datasheet that I can use as a stiffener for FPC. Parameters of stiffiner are: Pl's thickness - 100um, adhesive's thickness - 50 um. Thank you
[Others] How do I trigger a TIP32C PNP transistor with a 5V output signal from an NE555 IC?
I would like to know how. What voltage does the TIP32C need to make it as a solid state relay. Thanks for any help.
  • answered Aug 06,2020
[Others] Symbol fields are not in the correct place in schematic
Hi all,When I place passive symbols in a schematic the fields, they don't seem to stay where I placed them in the symbol editor and I can't seem to figure out what I'm doing wrong. Has any...
    by Kemio
[Others] Cooling problem---150W boost converter + 100W power LED
I have 12V 10A power supply (PC ) and I use 150W boost converter to raise voltage into 32-35 V (1,5-2A) . I added 15x10cm aluminum plate (5mm thickness , 3 cm fins) to cool LED (thermal paste added).I...
    by Kemio
[Others] Do anyone know how to make this amplifier run on battery
This amp run on 12-24v ac。
[Others] How to create a delay without pausing the code?
I want to make a pin HIGH for a specific duration of time, but I want the code to keep running while the pin is high, how do I do this?
  • answered Aug 05,2020
[PCB Assembly] when will this board be available on Bazaar ?
https://www.pcbway.com/project/shareproject/mXY_Board___Low_Budget_XY_Plotter_Drawing_Robot_Board.html authot said it would be available soon
