[Others] Speeduino Compatible EFI Shield
hello!Can I buy pcb forSpeeduino Compatible EFI Shield ?best regard Julian Gonet
[PCB Prototype] inverter 12v to 220v
where can i buy the pcb of inverter 12v to 220v?
  • answered Aug 03,2020
[Others] sbc188 questions
hi, i hope i contacted the right people.I am making an SBC188 and I have some questions to ask because I cannot find documentation on the site.How should the bios "diode resistor" be set?W...
[Others] ordering questions
Hi!I have few question abaout ordering. Mostly assembly based.I want to order 164x10mm PCB with white soldermask, no silkscreen, and with 5 pieces of SK6812RGBW LEDs (SMD5050) and 5 pieces of capa...
[PCB Prototype] Dose separate DC power require for "LIGHT AND MOTION SENSITIVE LAMP" Circuit?
If "LIGHT AND MOTION SENSITIVE LAMP" circuit run by 220VAC then will it automatically power the sensor and relay or separate DC power needs to apply?Why there are two relays in above c...
[PCB Prototype] Pcb traces
Why on some pcb's traces are like waves? What's it use case
[Others] Raspberry Pi Power Circuit Advice Needed
Looking for advice on improving this circuit. I use a 3S Li-Ion battery into a buck converter to power a Raspi trail camera with an on/off switch and led indicator.I use a largish resistor because I l...
  • answered Jul 31,2020
