I have a little setup in which I want to trigger certain events on the Arduino using Raspberry Pi's GPIOs. Therefor, I connected GPIO 21 to Arduino's digital Pin 5 and Pi's GND to Arduino&...
Can I solder my heatsink with a 0.3mm copper shim to reduce the gap between heatsink and ihs? I can only find PCB hand solder. can I heat up the shim with solder until solder melt and quickly stick it...
I am looking at designing a 2 layer PCB with through hole components that will sink 10 Amps of current. I understand that I need to make the width of my trace large enough to handle 10 Amps. My questi...
I need to duplicate high current tracks front and back. I have stitched vias and made a custom through-hole pad, also with stitched vias.However I can't get the last via-to-pad track to remain. If...
