[Others] Stencil design for BGA components in Eagle. should I disable the tCream layer for this package?
Hi all,I'm working on a design that uses a power switch(picture showed below) with a 6-UFBGA package to switch between USB and battery backup power. I will be placing the components by hand a...
  • answered Jul 13,2020
[Others] Eagle question: How to ground the mechanical pads of a part?
Hi everyone,I'm making a device with an SD card slot. The SD card holder is just a surface mount metal shell, and it has 4 foot pads that solder down, and are not electrically connected. I'd l...
[Others] Does anyone in Maker Space know the producer of headphone jacks marked with a K in a square?
Does anyone in Maker Space know the producer of headphone jacks marked with a K in a square? And honestly, who′d thought this was actually soldered onto a PCB? There′s almost no lead on the pins, no w...
[PCB Prototype] Could I share my projects receiving money for this?
I develop a lot of electronic projects and I want to share them but I want to get some money for it. Here are this option on site? You sell the project as PCB and after I receive some money.
[PCB Assembly] First time soldering. Can you offer some suggestions?
First time soldering. A lot need to improve, can you give me some suggestions?
[PCB Assembly] Adapter for programming SMD PICs
Sir. Very nice project. Do you sell the 3D cover for this?
[Others] Can I swap out the photoresistor with a photodiode, what should i pay attention
I'm in the process of building a project and would like some advice. It's a light-sensitive audio trigger built from a simple circuit interrupted by a photoresistor.However, photoresistors hav...
[Others] Can anyone explain the difference between simulation and emulation
I get confused about the meaning of simulation and emulation.Could anyone explain the difference in terms of programming? What is the difference between these two terms? Thanks
