I′m trying to connect the anode from a LCD 16x2 screen to 5V with a 220Ohms resistor. According with my Electrical Rules, it is not supposed to have an error between a Power Input pin and a passive pi...
I have a ton of LEDs from a flashlight that need 4.5-5V to turn on, and I want to control them with my Raspberry Pi 3.3v pins (The 5v pins are already in use). It looks like I need an NPN transistor, ...
I want to put in my PCB (two layers) an H-bridge motor drive that will control a high current motor (like several amps), that will be supplied by a separate power supply. Since it's a high current...
I’m working on an Arduino project where I want a motor( currently using a dc motor) to generate electricity and then reverse the polarity if it’s spun the wrong way. Any one know how to achieve this?I...
How to use an TXS0108E bi-directional logic shifter to convert 3.3V signals from a raspberry pi to a 5.0V signal to a relay board. I'm trying to trigger a 5 volt relay board using a raspberry...
Hi all,I'm working on a design that uses a power switch(picture showed below) with a 6-UFBGA package to switch between USB and battery backup power. I will be placing the components by hand a...
