[Others] Why can't see OK Cancel button in Allegro?
Help me, i can't see OK Cancel button?
  • answered Jun 26,2020
[Others] Can someone help\ Allegro.
Someone please help me fix this, I don't know where to find it. I use Allegro
  • answered Jun 25,2020
[Others] Trouble about placing the etch shape.
Hi guys, I'm new in Orcad. I met a trouble when place the etch shape (The PCB on the right). It override anything. The following PCB I drew at defferent time.
  • answered Jun 23,2020
[PCB Assembly] Can I place some components under the via IC on the other side of the PCB.
Hello, I have two through-hole ICs used with SMD components, and my main purpose is to reduce the size of the layout. Can I place some capacitors and some components on the under portion of the throug...
[PCB Assembly] Can anyone help? To ground the centre pad of the IC.
Hi,Can anyone help me out to rectify this error. I need to ground the centre pad of the IC, as tried of placing a via in the centre pad, and grounding it but I am facing this error. Thanks in advance.
  • answered Jun 22,2020
[PCB Prototype] Project Quote
Hi!, Im from Argentina. I must produce and assembly 100 pcs of 40mmx40mm PCBs single layer FR4. I'd like to know about the process of assemblying , how to proceed with the component list, and abou...
[Others] Payment through Aliexpress
Dear sirs,Are you still receiving payment through Aliexpress?ThanksJose Maia
[PCB Prototype] PCBway 2020 capabilities
can you please provide me with the current capabilities for 2020.minimum via, microvia, ratios, pitch, widths, etc.
[Others] Applying the post for designing engineer.
Dear Hiring team, Hello everyone ,i wish to apply for the post PCB Designing Engineer.I have more 2 year eperience in Electronics EMS industry. Saw your web portal and youtube video...
[Others] Tracks end too close??
Hi, For some reason, KiCad is claiming that these three tracks end too close to each other and also to a via, all in this one spot. But there is no via there.Is this a bug? There are four &...
  • answered Jun 19,2020
