Hi, For some reason, KiCad is claiming that these three tracks end too close to each other and also to a via, all in this one spot. But there is no via there.Is this a bug? There are four &...
Hello,I would like to know some information about capabilities of double sided aluminium PCBs with both core in the middle and on the bottom.What is the stackup for these configurations (especially fo...
Hello--I'm designing a board for someone and they said they're going to submit the board to your company. Is there an easy way for me to submit the board to check whether it can be manuf...
Congratulations, nice work... Could you share arduino * .ino code for a sample study. Or do you have a sample video in YouTube? Selamat, kerja bagus ... Bisakah Anda membagikan kode arduino * .ino ...
Hello guys, It is my first time to lay out a BGA, It's a 9x9, so not huge, but it has .4mm pitch so I'm using vias in pads (filled) to breakout the signals.The bottom layer of the board i...
https://youtu.be/0QjO08HNXos1) mXY board with components used for XY polygraph printer, when will it be available? I want to buy 2) Can I also have the gandola and other spares to assemble the pr...
Goodmorning,on instant quote I can set number of different designs in panel.I don't know if there are extra processes for multiple designs in panel (let's say some additional check, I suppose....
