[PCB Prototype] Amiga 1200 RTC Module
Hi,Could you tell me what is correct value of C2 capacitor? I found this project on: https://www.amigaworld.de/hardware/amiga-1200-rtc-module/ but I think 10mF is not correct.Regards,Szymon.
[PCB Prototype] Dielectric Constant for specific Laminate type and thickness
I need to design a board with high speed signals like DDR3. I see that its possible to specify what type of laminate to be used. But when specifying the stack-up and the laminate thickness between sig...
[PCB Prototype] why pcbway is not approving project added from shared project
I am adding to my cart project from shared projects .. https://www.pcbway.com/project/shareproject/air_solderin_station_ver__2.html but PCBway staff is telling me Audit FailedFailed re...
[PCB Prototype] Blind vias in PCB quote
Hi, If my design contains blind vias, PCB material option should be "HDI" instead "FR4" in on-line quote?. See picture below:Thanks
[PCB Prototype] Prepare panel of small board
Hello,I want to send you my design. My board is 30mmx40mm. I would like to order a panel. What is the standard suggested panel size where i can utilize the space.Thank youDimitar
[PCB Prototype] Need some baords made.
I have the Eagle file but cant figure out how to export the gerber file that you require.can i email it to you for manifacture?
[Others] Restock of Solar Powered WiFi Weather Station V2.0
Do You plan to restock supplies of Solar Powered WiFi Weather Station V2.0and if so when?
[PCB Prototype] pcbway share community
when we share projects on the pcb way open community then we choose the "gerber not allowed" option which means that the pcbwayers cannot download the gerber and hence they have to order it ...
[Others] First order sponsorchip free???
Hi, How i can use first order free by sponsorship. I have one sponsorship approved in june, but i can't use it?
[Others] PCB design contest
Goodmorning,I have some questions about contest:- I can see there are many shared projects providing images and desctiption, so I suppose them are "finished" projects- on rules it's said...
