It is because the cutouts/sots design in silkscreen layers. Then it is hard to recognize them as slots and our engineer just take them as texts frames. We suggest to design the cutouts in outline/GKO/...
With the initial requirements and constraints determined, several choices must be made. A compromise is made between the available materials, the required current requirements, board thickness, an...
Hello! How are you doing?I would like to know how can I buy a pcb lot of projects published on your site?https://www.pcbway.com/project/share/Manolena_SMD_Solder_Station_with_Arduino_Nano.htmlhttp://w...
Hello, i need to protect my automotive PCB, with LED, from electromigration, to avoid creepage current. The customer req is 1,1 mm beetween power supply track, i instead have no more 0,25 mm gap. so h...
Hello was thinking of getting a few of you 8mb accerlerator pcb boards will i need to use both boards was hoping you can help me to obtain the correct parts i need be nice to see your produc...
Hello I have iv-21 tube and i want to build a clock with this tube can you help me and send pcb schematic and pcb design and part list For this tube? best regards
