Hola, gerber generado por eagle, no aparecen las perforaciones en el visor de gerbers (en PCBway, en otros sí). A que se debe?Hay un proyecto que subieron al concurso que no es de su autoría (conozco ...
Hi from TurkeyYou are doing great. Thank you very much.I decided to make my own DIY electric violin. (I am luthier for acustic violins)I want to use under bridge pickup (probably it calls piezo ).So i...
Dear Madam/Sir,I need to fabricate a prototype circuit.1- Can you fabricate MHMIC circuit on the ceramic substrate?2- The circuit needs an integrated resistor (100 ohms/square). 3- The metallizat...
Hi,I need to fabricate several circuits in MHMIC (Miniature Hybrid Integrated Circuit) technology. I use in my simulations a high dielectric constant thin ceramic substrate. The permittivity is ...
Dear Sir / Madam, I came across the Dolby Prologic Surround Decoder 5.1 Channel Audio Processor SSM2126A project in your website The Author of the article mentioned that he shared the ...
