4ChannelLedStrip Control with Nodemcu Please give schematic diagram. I have ordered and recieved designed PCB but I am not sure about transistors used in it.
This board can't be made.. Because Nathan Rochester hasn't add the boards outline inside and either the boards screw holes.. Plus the edges that are not need....
I use a nodeMCU on a solderless breadboard, connected to a simple 3 pin RF transmitter that has an antenna soldered on to it.I found this NodeMCU breadboard: https://www.pcbway.com/project/sharep...
Hello all! i need help with a design for a pcb.I want to make a speed camera that can detect how fast a car is going and then send that infomation to a nother pcb curcuit that will then send that mess...
Good day!What will happen if when ordering installation of components on the board, some of them will have restrictions on the delivery to the destination country?
Dear,I′m starting with the design of my PCB. The highest frequency that we will have on it is 30MHz. We know that is not necessary but we want to design a four layer PCB.Can someone help to desig...
