[Others] programming delivery
Hi We use PCBWAY for fast delivery in Italy. I want know if is possible have a possibilities of programming production and delivery with more time ( 2/3/4 week ??) and use a courier less expensive of ...
  • answered Jul 20,2019
    by sachin
[PCB Assembly] What kind of files are needed for PCB Assembly service and how can i gernerate it from Eagle?
What files are needed for PCB assembly service and is there an ULP or CAM job file available to generate it automatically from eagle?
[PCB Prototype] the message "Please Select Finished Copper" appears when ordering
Dear Manager,When I am going to order this shared project,the message "Please Select Finished Copper" appears after a selection page of amount and silk, etc.https://www.pcbway.com/project/sh...
[PCB Prototype] If slot repeated with drill on my design, will you produce as slot or drill
Rep:It is better for customer to delete those places do not need when checking the design file.
[Others] construccion de pcb
se?ores:es posible la fabricacion de una pcb a partir de una muestra ya que las que tengo son demasiado delgadas y se fracturaronATTEsoy de CHILEVICTOR
[PCB Prototype] Pad not correct
https://www.pcbway.com/project/member/?bmbno=A8E6844A-838D-4Athe pad for the power terminal is not correct and PCBWay won't do the boardhttps://pcbwayfile.s3-us-west-2.amazonaws.com/web/19/06/24/1...
[Others] I can solder
It looks like I'm late for "I can solder kit 2019", so will you repeat this contest next year?
[PCB Prototype] Will you be able to make a PCB which uses WLP, pitch/e=0.4 mm?
Hi, I have a PCB with e=3.5 for the WLP ball pitch, and e=.4.Will you be able to fabricate/assemble boards that use these ball pitches(max32664 (also available in tqfn), max86141 (only available as wl...
[PCB Assembly] Want to make my first project with you - including assembly service.
Hello.I've registered to this great site a long time ago.Didn't order nothing yet.Really want to make/see my first assembles PCB from you.I've seen shared projects that include PCB prototy...
[Others] Blank PCB mask samples? Color swatch?
Do you offer any type of blank mask, color swatch, or finish samples, like the following image?To be clear, I am looking for a physical sample. A swatch (multiple samples, like image above) would be i...
