Hello, I'm looking to have a board made and assembled by PCBway and I have a question about how you handle irregular shaped boards with your assembly process.Will there be tabs or vscores ar...
Hi, does pcbway accept semi-finished PCB assembly?I mean not all components in the bom, just part of them, because some components maybe need to be adjusted according to the test.
Bns svp lorsque vous avez passer ta commande tu a passer comme personne physique ou morale et est-ce que vous trouvez une probleme avec la douane tunisienne et mercie d'avance
I followed the steps I filled out the instant quote, went to the order screen, cleard review...There is no blue SHARE/SELL button showing up for me as indicated to this page:https://www.pcb...
Its not clear to me how i place an order. Im assuming that i need to upload everything on your web site (BoM, Gerbers etc). Is this assumption correct, or can i email a complete package of the boards ...
Hello! We are extremely pleased with your PCB service and delivery!! Do you also manufacture Membrane Switch Panels? If not, do you know of a company similar to yours that can make membrane switch pan...
