[PCB Prototype] Looking for PCB manufacturer of Satellite
Our company is located in South Korea. We are looking for PCB manufacturer of Satellite.If your company could supply them, please contact me.Thanks,Wonny, Lim
[Others] blood pressure and measurement of heart rate on arduino device
I need to integrate on arduino devices o similar these function: blood pressure, measurement of heart rate, Pedometer and Steps countingI would like use esp8266 device or please I'm looking f...
  • answered Jun 10,2018
    by Darko
[PCB Prototype] Minimum distance between traces for 250/400VDC
HelloWhat is the minimum distance between traces/polygons on your PCBs for voltages like 250V or 400V? is 66 mils/1.7mm enough, it could be less, or more?My current desing:
[PCB Prototype] If I select PCBWay to make a panel and add rails how do I fill in the form on the website?
I have two different PCB designs (A and B) that are used in pairs so plan to put both on one panel to minimize NRE costs for assembly. Each board is 75 mm x 85mm. After reading the information on the ...
[PCB Prototype] If I have a design that needs V groove cut, what gerber file extension should they be in?
If I provide a design to PCBWay that will have rails that will be seperated after assembly with a V groove cut, what gerber file extension should be used and/or what note(s) should be added to the ord...
  • answered May 22,2018
    by PCBWay
[PCB Prototype] Why did your technical reviewer reject my order?
I want it 2 layer even though there is no track on the bottom, I only need the soldering pads.
  • answered May 18,2018
    by PCBWay
