[PCB Prototype] SD card format and how much memory, anything to program on it?
do i need special format of SD card. FAT16 or?Do i need program code on sd-card?
[Components] PCB and component purchase without assembly
Hi!I was wondering if I can order a PCB and a BOM without PCB component assembly?I have a tiny PCB, with few components and a very little budget and I am triying to reduce costs by assembling myselfTh...
[Software] PS/2 to 1351 mouse converter firmware sources
Hi Alfred,I can see you enhanced the firmware for PS/2 to 1351 mouse adapter. I have built 2 pcb but I'm having some calibrations issues. Can you share the source so that I could update OSCCAL and rec...
[PCB Prototype] GERBER FILES
Hi, is there any possibility to purchase gerber files? Thanks
[Injection Molding] General questions about injection molding capabilities before submit a quotation
Hello,We are a startup looking to develop an electronic lock and need a company to create the molds and plastic parts. Our product will be used on garbage containers, so it must be resistant to water ...
[PCB Assembly] SMD connector with plastic pins : SMD or THT in assembly BOM?
I have a connector which is an SMD part, although it has plastic mounting points which protrude through holes in the PCB. They do extend slightly beyond the bottom of the board.For assembly purposes, ...
[PCB Prototype] I'm only getting 10v out of the OPIC .VM
Hi Mic I've just finished your voltage multiplier bom but unfortunately im just getting 10v of output for bias voltage, It supposed to be 60v with 3,3k. The only difference I've notice is that R14 is ...
[PCB Prototype] KiCad Files
Hello! I am also from Ukraine originally. Can I get a KiCad files for this project?I am Integrating it into my project and this would really help. Thank You!
1 ... 20 21 22 23 24 25 26 27 28 29 30 ...
