[PCB Assembly] Does PCBWay offer services for panelizing small PCBs for assembly? What is the manufacturing fee if we need help panelizing?
Yeah so I am working in a group project utilizing surface mount components which are too small to be soldered manually, I was wondering if PCBWay does panelization or not for small components.
[PCB Assembly] Is it possible to switch some SMT components on the PCB design that have the same dimensions and pad but different properties (1uF vs 10uF) within a single order?
I have a signal conditioning circuit with various stages. In one stage I want to use a 100 Ohm resistor. However, on a different design, I want the same design but using a 200 Ohm resistor instead. Is...
[CNC Machining] Copper type for CNC
What is the type of copper you use for CNC? Is it oxygen-free high conductivity copper (OFHC)? If not, can you give the type or a reference?
[PCB Prototype] ESTA PLACA YA ARMADA COMO SE VE EN LA IMAGEN LA VENDEN? SI ASI ES COMO LA SOLICITO?
[PCB Prototype] 3 pins on the side
Hi, you use the 3 pins on the side, if I have a row of 3 can I insert it or do I have do cut the row of 3 into single pieces to fit?
[PCB Prototype] hello, I need 1pcs AMIGA 1200 KEYBOARD MEMBRANE REPLACEMENT (FFC VERSION)
[PCB Prototype] I would like to add your 24v battery busbar to my (8) 3.2v LifePo4 cells to build a 24v battery . will this busbar work? Model LF 280k. 896wh.
I would like to add your 24v battery busbar to my (8) 3.2v LifePo4 cells to build a 24v battery. Will this busbar work?Capacity 280AhEnergy 896Wh
[PCB Prototype] Does pcbway clone/copy service double sided pcb boards
Looking to have a very small double sided pcb board cloned/copied do you do that service. Board is 23mmx23mm in sizeThanks been using pcbway past 7 years
[PCB Prototype] Small air gap milling
Hi. Is it possible to mill out air gap with minimum width 0,4 mm? Picture attached.
[PCB Design] Need a beveled edge for pcb to insert into a edge connector.
My order number: W527816AS2Y1 My question: This design has edge fingers, the pcb gets inserted into edge connectors. I would like the edges tapered, do you or can you create tapered edges for edg...
1 ... 30 31 32 33 34 35 36 37 38 39 40 ...
