[PCB Prototype] Ready-assembled PIPPYG sought
Hi, I have just come across the PIPPYG 3.0. Is there any way of buying one or two ready-assembled? I don't have the knowledge or skill to assemble the kits. I have two ready-assembled AudioMoths which...
[PCB Prototype] what are these beans you speak of
what are beens
[PCB Prototype] Custom transformer?
HelloCan you do custom transformers and assemble connectors?See attached picture.
[PCB Prototype] What is radius of corner in rectangular slot?
Can I draw the minimum slot with 0.8 mm width as a rectangle? And what will be the final radius of the corner after manufacturing? Best Regards, Piet
[PCB Design] I have an old PCB (with RGB LED) board that is shaped like a T. Would it be possible to send in and have it remanufactured?
As title_ says I have an old PCB bought from a vendor that is no longer in business. It is damaged but is still functional. Would love to have replacement boards made to use. Its basic RGB in a shape ...
[3D Printing] UL94V0 plastics
Do you have any materials to print non-flammable UL94-V0 details?
[PCB Design] What's the maximum length pcb you can make with a width of 2.54 cm?
[PCB Design] Soldermask clearance and solder bridge sliver
What is the minimum solder bridge and solder mask clearance for matte black solder mask? I found it says 150um for solder bridge and 0.75um for soldermask to pad clearance, but it is not consistent wi...
[PCB Prototype] Is it possible to import a .dxf file into CircuitCam (LPKF) from a Fusion 360 3D design?
Hello,I am relatively new to this, and still just trying to get my bearings with these programs. My goal is to mill relatively simple circuit boards on a protomat, starting with a Fusion 360 design. H...
1 ... 32 33 34 35 36 37 38 39 40 41 42 ...
