[PCB Prototype] what is the recommended pad size diameter for 0.4mm pitch BGA
I have a 185-pin IC with a 0.4mm pitch. Is it necessary to use blind and buried vias? Is there a more cost-effective method for wiring? If there is no more cost-effective wiring method, wh...
[PCB Prototype] How to Make a 12V Lead Acid Battery Charger with CC & CV
helloplease help me.After transferring the file to the altium, the PCB file is faced with error.Please email me if possible.(hosseinjavidian@gmail.com)Thank you
[PCB Prototype] Can you provide Arduino Sketch for the self balancing Robot?
Can you provide Arduino Sketch for the self balancing Robot? I have the PCB and all the parts are soldered and working, but I'm not a programmer.Thank you very much!czecht@gmail.com
[PCB Prototype] LED Matrix and Lissajous pattern Generator the 100x LED version?
You mentioned that there is a 100x LED version of this educational project Would it be all possible for you to provide me with the link to the 100x LED version as well as the order number for PCB, The...
[PCB Prototype] Routing and via to trace clearances
Could someone please tell me if this sub-part will be okay ? (it is incomplete, just a sub-part meant to be integrated onto a board) Will it pass engineering review without issues ? (Options to select...
[PCB Prototype] Drill diameter meaning in NC drill files ( fineshed hole or drilled hole ? )
Hello!I have a question regarding drill files: How do you interpret the drill diameters in the NC drill files in case of plated through holes by default ? As the finished hole size, or as the drilled ...
[PCB Prototype] DJI PHANTOM 4 DRONE
Please how long does it take PCBWAY to approve your project ?
[PCB Prototype] Milling grooves in PCB, how to specify?
I need some shallow grooves milled in the PCB, how do I specify the width and depth of these grooves?The PCB material is 0.6mm thick is it possible to mill 0.25mm deep grooves?
[PCB Prototype] Ac motor controller
AC 220V 15W asinkron motor controller for vinyl turntable D drive.Hall senzor digit display RPM Adjustable+-5%
[PCB Prototype] how to search
where is the search function within this site?
1 ... 27 28 29 30 31 32 33 34 35 36 37 ...
