I am planning build a "DuoTech MediaStation," which will serve the role of both a Linux-based PC and an Android-based TV. The device will have power button, HDMI-switcher button, a speaker volume butt...
I have tried ordering a small run of your RAD for Pi Zero 2W. I was told that PCBWay needs a Centroid file. I only have a vague idea of what that means, and no idea how to create one. Any help is g...
Greetings,I am looking for opportunity to assembly simple and little PCB as RAM module.2x chip memory GM71VS65163CL per ONE module with EDGE connectorIt is very hard to solder it correctly. Could...
I want to create a basic shape from aluminum 6061. Are there standard thickness options for flat rectangles in this material? The exact thickness doesn't matter to me, and if I choose a standard thick...
If we order this product at PCBWAY, which products exactly does PCBWAY deliver?Is it a fully finished product? Is it just the PCB, is the screen and Dock (J-LINK OB) included?Please, if someone in aut...
Hi -- I'm designing a board in Kicad and exporting via the PCBWay plugin.Do I need to worry about silkscreen that is clipped by the solder mask, or is this automatically removed by PCBWay?If I was not...
