[PCB Prototype] Minimum spacing between plated pads of a QFN (0.4mm pitch), for standard PCB manufacturing (quick-order).
Hello PCBWay, your services have been absolutely great. I was wondering, what is the minimum spacing between plated pads, such as those of a QFN package, because I saw somewhere that it was '0.2mm', b...
[Others] Can you add "CC0" in the license selector when sharing a project ?
My projects are licensed under the CC0, but I cannot select that exact license when sharing a project.Regards.
[PCB Prototype] microchicken question for Tor-Erik
Dear Tor-Erik, thank you for developing the microchicken system. I am looking forward to complete my SBC during the next couple of weeks.When I stacked the SBC and UI boards I noticed that the visibil...
[CNC Machining] hello! i am located in Shanghai China. can I use your service? you can ship to me in Shanghai? Thanks! Brian
hello! i am located in Shanghai China. can I use your service? you can ship to me in Shanghai?Thanks!Brian
[PCB Prototype] Does the FR-4 2-layer circuit board have a UL certificate?
[PCB Prototype] what is the minimum via size
what is the minimum via size on a pc board
[CNC Machining] Can I send you a metal part for you to make 3d drawing out of?
And then machine the parts for me? I don't have the drawings
0answers
[PCB Prototype] do your boards work?
Hi mister,Have you released the openevse board ?Did you have any problems with it during testing?I made cards but couldn't get them to work. I have problems with the pilot signal.Problem with +12V -12...
[PCB Prototype] cga rgbi converter assembled pictures (both sides)
Hello,Do you have closer pictures of the cga rgbi converter once assembled ?I ordered the pcb and components. And as a first for smd soldering,I need closer pictures to know if I am putting components...
1 ... 37 38 39 40 41 42 43 44 45 46 47 ...
