How would I go about getting a quote for a pcb fab and kitting of through-hole components that go onto the pcb? This is for a student built electronics kit used in our non-profit organizations program...
1. Setting of the schematic drawing1. Double click the edge of the drawing to enter properties, you can set the drawing, in order to table size, drawing color, drawing size, direction, label, and edg...
Hello guys, I need to find this wpc005050-0001 board. This boards are from speakers Genius SW-HF 5.1 5050 V2, i need to find this board and buy it and i need to have fully working both board...
I have a 185-pin IC with a 0.4mm pitch. Is it necessary to use blind and buried vias? Is there a more cost-effective method for wiring? If there is no more cost-effective wiring method, wh...
helloplease help me.After transferring the file to the altium, the PCB file is faced with error.Please email me if possible.(hosseinjavidian@gmail.com)Thank you
Can you provide Arduino Sketch for the self balancing Robot? I have the PCB and all the parts are soldered and working, but I'm not a programmer.Thank you very much!czecht@gmail.com
