[PCB Prototype] details about the project of line follower
Hey, Can you please let me more details about the project of line follower
[PCB Prototype] I want to know if I made the timer schematic accurately
Hi, I want to make a timer PCB that contains 3 high power relays (230v @ 30amps). The traces for these relays must be able to handle that current. I was wondering if I first made the timer schematic a...
[PCB Prototype] Can I upload 3D objects for sheet metal manufacturing, or do they need to be flat?
I am working on a sheet metal project that has three separate parts. The parts are designed in Fusion360 using the sheet metal toolbar. I am new to this design process and have a few questions to make...
[PCB Assembly] Can I order the (DIY) ATARI 2600 MULTI GAME CARTRIDGE (64x4) with the sockets, dip switches and chips already installed?
[3D Printing] Question about 3D printing.
Hello, can you print cases according to this specification?3D print is fine now but this is a medical device so high quality injection mold will be desired later.
[Others] Will it affect the drone performance if I modify flexible cables and make them longer?
Hi,I have an old broken DJI phantom 4 pro without a remote and battery that I'm trying to modify and build a new drone using its internal parts. However,the problem I'm having with the planned design ...
[PCB Prototype] account closure
how do i close my account
[SMT Stencil] Stencil design as shared project
Hi, Can SMD stencil design be uploaded as a shared and licensed project? What are the minimum data (gerber layers) you need for stencil creation?
[PCB Prototype] I have a request to make: can you produce a board based on the schematics I provide?
Greetings. I have a request to make: can you produce a board based on the schematics I provide? Every component - resistor and capacitor are of SMD 0805 sizeActual values of resistors and capacitors c...
[PCB Prototype] What is the CTI value for the standard FR4 material used?
1 ... 21 22 23 24 25 26 27 28 29 30 31 ...
1 PCBWay Team 8
2 Engineer 1
