[PCB Prototype] LED Matrix and Lissajous pattern Generator the 100x LED version?
You mentioned that there is a 100x LED version of this educational project Would it be all possible for you to provide me with the link to the 100x LED version as well as the order number for PCB, The...
[PCB Prototype] Routing and via to trace clearances
Could someone please tell me if this sub-part will be okay ? (it is incomplete, just a sub-part meant to be integrated onto a board) Will it pass engineering review without issues ? (Options to select...
[PCB Prototype] Drill diameter meaning in NC drill files ( fineshed hole or drilled hole ? )
Hello!I have a question regarding drill files: How do you interpret the drill diameters in the NC drill files in case of plated through holes by default ? As the finished hole size, or as the drilled ...
[PCB Prototype] DJI PHANTOM 4 DRONE
Please how long does it take PCBWAY to approve your project ?
[PCB Prototype] Milling grooves in PCB, how to specify?
I need some shallow grooves milled in the PCB, how do I specify the width and depth of these grooves?The PCB material is 0.6mm thick is it possible to mill 0.25mm deep grooves?
[PCB Prototype] Ac motor controller
AC 220V 15W asinkron motor controller for vinyl turntable D drive.Hall senzor digit display RPM Adjustable+-5%
[PCB Prototype] how to search
where is the search function within this site?
[Others] where is the search page?
i am looking for a search page
[PCB Prototype] Hi Justin, I hope you are doing well.My question is: is it possible to port everything to a 1st gen mini board but adding the extra features of the 2nd gen? Thanks so much for your input. Dre
[PCB Assembly] Can you source and assemble this oddly shaped LED?
TL;DR: Manufacturer is Inolux - Part number is IN-PI32TAR5R5G5BHello. I've only ever used JLCPCB so far, but since they don't have the part I want on LCSC I thought I should look into PCBWay. I've...
1 ... 24 25 26 27 28 29 30 31 32 33 34 ...
