I need an idea of cost for Copper PCB with thermoelectric separation. In attacched file, the Thermal pad are all 6mm round type. 1L, 1.5mm thickness, 1oz, white color solder mask with black silkscreen...
What is the best way to add slots in SprintLayout?People suggest a lot of different things, ranging from thick outline trace (same dia. as milling bit), bunch of through holes placed real close to eac...
Bu adım adım kılavuzda, elektronik projeleriniz için otomatik şarj kesme kontrol devresi nasıl oluşturulur, size göstereceğiz. Siz bir hobi ustası veya bir elektronik meraklısı olun, bu devreyi nasıl ...
I need a 6 layer PCB stackup with a low loss dielectricum to the top layer.Can you change the top dielectricum of your normal 6 layer 1.6mm stackup to RO4350 0.101mm?Do you suggest a nother stackup?If...
Solar Powered WiFi Weather Station V3.0: Does this board come complete with all of the components except the sensors? I know in the past there was a chip shortage that made some of the components hard...
When you part has M3 x 0.5 threads or any threads. Do you prefer the threads to be modeled into the part or just a hole? Then note the threaded holes on a print or drawing?
