[PCB Assembly] Crystal Clear GBC Flash Cart
Hey!I am interested in assembling the "MBC30 Flashcart | 4MB | FRAM | RTC | Crystal Clear Edition". This is my first time using pcbway so my question is if the Flash Cart is 100% completed a...
[Others] I would like this PCB board analyzed for problems and a list of components for repair
HelloI need to know as much as possible about this PCB board including any issues that would prevent its correct operation and a component list. This item is an Air conditioner controller board ...
[PCB Prototype] Alexa PCB components
Hi youmaker does not have the link of the big alexa anymore can you tell what are the components for the PCB
0answers
[Others] About mega drive fram 4mb pcb
Hi, really amazing pcb. I am looking for the same but compatible with Sega 32x cartridge shell, so only can put holes in different place. Is it possible that you can make one compatible with 32x and m...
[Others] How do I update this project page?
I put these files up a while ago and abandonned it as I could not figuree out how to create a multi-PCB/page project at that time. Now I am here to update the whole thing. There does not seem to be a ...
[PCB Design] How to use circuit board jumpers? - SparkFun jumper issue JUMPER_2_NC_TRACE_NO_SILK won't route under EAGLE 9.6.2
I asked this question over at the SparkFun forum and someone suggested I post is here because there may be more EAGLE users here.I'm using the SparkFun jumper library under EAGLE but having proble...
[PCB Prototype] All tolerances (also XY) of z-axis milling?
Heyho PCB-Way Team,I checked already the PCB capabilites, but I couldn't find a page where I can find the z-axis milling tolerances.I'm saw that there was another forum-thread, where the suppo...
[PCB Prototype] COMMODORE 64 - KERNAL TABLE (901227 KERNAL ROM REPLACEMENT ADAPTER)
Hi, I am discovering your website. Can you please confirm if the item described is sold mounted ? Can you also confirm it can be used as a simple adapted for a 28pins eeprom into a 24pins socket?...
[PCB Prototype] LM3886 composite power amplifier
Hello, it looks interesting! Would you let me see the specifications, measurements and the schematics?Also, witch is the price for 2 pcb?Thank you very much!
1 ... 41 42 43 44 45 46 47 48 49 50 51 ...
1 PCBWay Team 9
2 Peter de Vroomen 1
4 gokul kb 1
