[PCB Prototype] None color
What color is none?
[PCB Prototype] Gerber G75 arcs?
Should submited gerber files use G75 arcs?
[PCB Prototype] 10k pure wave 48vdc to 220vdc dutttty cycle! possible or not ?
i do you think its possible to built a 10k pure sine wave inverter ...48vdc to 202vac duttty cycle ?tanks
[PCB Prototype] Should I get a stencil?
Hi! Ive used Osh to make PCBs for RGB chips I used to make with solder paste and a hot air workstation. Is this project about like that? Should I get a stencil? I have ben making custom Gameboys and I...
[PCB Prototype] Firmware question regarding SC64 Project
If I order this with the firmware loading option would that include flashing of the FT232H, the STM32, and the FPGA? As shown in the documentation on the GitHub
[PCB Prototype] Peugeot 3008
Hi, I need to replicate an electronic board from a Peugeot 3008. Is it possible?
[PCB Design] Eagle Gerber
How tocreate gerbei files in Eagle 7.2 ?
0answers
[Others] Play module question
Do you have a timeframe for when you might be adding the files for the Play module?
0answers
[PCB Prototype] Bus Bar Template
Do you have a design of you bus bar that would work with Lifepo4 batteries in the 280ah plus range?Thanks,
1 ... 43 44 45 46 47 48 49 50 51 52 53 ...
