I bought this clock from you shophttps://www.pcbway.com/project/gifts_detail/RGB_Glow_Tube_Clock_907ad35c.html it's indicated there is a software to change and do some DIY things, but there ...
Hello,I am interested to buy Kokot PCB (by freedom2000) and all material (meaning all electronic and mechanical parts), but I do not want to pay for assembly.Is it possible?Thank you and kind regards,...
Hello everyone,I am looking for the smallest possible programable timer PCB prototype with RTC, relay and Bluethooth including firmware.This prototype will used to be programmed to light up a tiny 5mm...
Can you help in making circuit diagram and pcb design for accident prevention in the hilly region by using Arduino UnoGreen and red LEDUltrasonic sensorIR sensorTransistorResistorLED
1. Can you provide the circuit diagram in the Joystick Hand Controller ESP32 to ESP32 video?2. Can you provide the circuit diagram in the ESP32 Mecanum Wheels Robot and Bluetooth Gamepad Controller vi...
Hi,Does anyone know what is the maximum depth the CNC can cut into? I need to make a box with out side dimesion 100x80x65 mm and internal dimension of 80x60x45 mm. There will be no top at the box.
Currently running the older Game plan ver 1.3 on my foxy lady coctail but no score or credits display.. Im curious if a diagram has been or could be made of what to jumper to make work like the ver 1....
I bought a PB-503 that had been used in an electronics teaching school. The school may have altered the pin placement/connections to fit their in-house power, in the 4 wire round power supply plug tha...
