Hi,I would like to have a quote on a fully assembled and printed as well as all the Solar panels and extra sim Stem boards and UHF etc...a full copy of the project assembled and a extra 1u or 2u of ex...
HelloI need to know as much as possible about this PCB board including any issues that would prevent its correct operation and a component list. This item is an Air conditioner controller board ...
Hi, really amazing pcb. I am looking for the same but compatible with Sega 32x cartridge shell, so only can put holes in different place. Is it possible that you can make one compatible with 32x and m...
I put these files up a while ago and abandonned it as I could not figuree out how to create a multi-PCB/page project at that time. Now I am here to update the whole thing. There does not seem to be a ...
I asked this question over at the SparkFun forum and someone suggested I post is here because there may be more EAGLE users here.I'm using the SparkFun jumper library under EAGLE but having proble...
Heyho PCB-Way Team,I checked already the PCB capabilites, but I couldn't find a page where I can find the z-axis milling tolerances.I'm saw that there was another forum-thread, where the suppo...
Hi, I am discovering your website. Can you please confirm if the item described is sold mounted ? Can you also confirm it can be used as a simple adapted for a 28pins eeprom into a 24pins socket?...
