[CNC Machining] Modeling threaded holes?
When you part has M3 x 0.5 threads or any threads. Do you prefer the threads to be modeled into the part or just a hole? Then note the threaded holes on a print or drawing?
[PCB Prototype] Biocompatible soldermask?
Do you have soldermask options that are biocompatible? I am looking into making a lab-on-a-chip PCB for a project and i am wondering if i can let bacterias in a salt water solution run over the solder...
13answers
[PCB Prototype] screen printing or writing without solder mask and copper
Hihow to obtain screen printing or writing without solder mask and copperlook at the photoThank you for answering me
[PCB Prototype] stack up for 8 layers PCB
Hello, do you stack up for 8 layers PCB
[PCB Prototype] Attiny 1616 CAN Bus PCB
Hello friend, I would like to ask you for the gerber files or EasyEda PCB file for "Gerber_PCB_ATTiny1616-Minimal(QFN) with CAN Bus", I am from Russia and cannot order boards from PCBWay, they do not ...
[PCB Prototype] I wonder if it can be applied to the 2011 Passat B6
Hello, is this applicable to the 2011 Passat B6 sedan? I'm Korean so I don't know how to order. First of all, if it's not just PCB, there's PCB and assembly. What's the difference? And after selecting...
[PCB Prototype] How to read PCB
How can I find out what the number in letters definitions that's on pcb
[PCB Prototype] Adding Hard Gold Finish to One Side of my PCB
I would like to add a hard gold finish to my PCB for better cycling durability with pogo pins . Is there any special conditions I need to add to my board in order to add hard gold to one side of my pc...
[PCB Prototype] Values of the PIC configuration bits?
I realy like the CRAB apple1 board and I build one, but now I have to program the PIC controller. I want to use the .hex file for my programmer but I would like to now the values of the configuration ...
1 ... 52 53 54 55 56 57 58 59 60 61 62 ...
1 PCBWay Team 9
2 weslley ramos 1
3 Epishko Dmitry 1
