[PCB Prototype] Non standard PCB thickness
(1) Can you manufacture prototype PCBs at 0.3mm thickness?Required board would be approx. 20mm x 20mm with 0.1u ENIG finish
[PCB Prototype] Hole tolerance
Hi,What is the tolerance on drilled and plated holes?
[PCB Assembly] Breadboard circuit construction
For the random number generator roulette circuit, can I substitute a touch switch in place of the touch wires?
[Others] Redeem products in exchange for beans
Hello!I have a question that is not necessarily related to PCBs, rather about PCBWay and beans.I've been trying to gather beans for a while to change with a JCD soldering kit and an Arduino Mega, ...
[PCB Assembly] class d sound applicator
Good evening I am interested in a project of a high power class d amplifier and it is the first time that I am going to use this system but I need help from you if you already have a design.For me to ...
[PCB Prototype] copper clad board oxidation removal
I'm new to PCB making for prototyping... I have some old copper clad stock, but its oxidized (salmon color on some and dull finish on others). waht's the best way of removing the oxidation? I ...
1 ... 74 75 76 77 78 79 80 81 82 83 84 ...
