If I upload a design that uses pure DVI protocol (no audio, no HDCP, no logo) over an HDMI connector, are there licensing issues if I share that design with the community? I read that there are ...
Good dayIs it possible to change the gerber files of a shared project?I have a shared project, I have made some few improvement an dwould like to edit it.Is it possible? How?Thanks
All my old pc boards were made using tape and 1 to 1 negative's. All are single sided and relatively uncomplicated.Is there a way for me to convert some of them to a Gerber file so I can use your ...
Is it possible to fill a standard 10 * 10cm module with a board from this project? So that there are 4 such boards on a standard 10 * 10cm module. How to do it and how much will it cost?https://www.pc...
SA a?bim bu 1200w amfinin sende kart? mevcut ise al?c? olmak isteriz ?orumdan ileti?ime giriyorum 05541197683 numaral? tlf mesaj atarsan sevinirim a?bim.
I'd like to order boards and design a test jig and/or fixture to do some functionality tests after assembling them before installing into the device.If I select "Panel by PCBWay" when or...
Hi,I've realised that you used AP63205WU-7 on your previous projects. Do you have a small quantity (e.g. 25pcs) on stock that you could sell to us?On mouser and all other stores this typ...
