Hello,I am desiging a 4-layer RF board with 50 ohm impedence control for RF signals. I need the following information from pcbway before I finish up the layout and submit the order: 1) What...
HelloI made this detector but it doesn't work.Can you explain the problem more clearly?Another question, what does p + and p- mean?Finally, 7905 gets very hot. Thank you for reading.
I have a PCB I would like to be fully assembled by PCBWay that includes a matrix of 25x 3535 RGB LEDs. I have read the SK6812 mini LEDs can be very sensitive to soldering temperatures and may fail.&nb...
Hello experts, very unusual question: In my design the top surface of the PCB as used a mechanical surface (think of a hockey puck sliding around on it).What materials as part of the pcb fab...
Hello, I need to make a single-layer IMS PCB due to the high temperature operating temperature of my design.I need to connect some wires or connectors from the bottom side of the IMS PCB.Is this ...
Hi, I ordered FPC from PCBWay which 0.15 mm thickness ( 1/3 oz copper, 2-layer min. track width 0.06mm)I will use this FPC in my senior project, but i need mechanical properties like density, you...
I have the schematics of a device in pdf. I also have the BOM in an excel file. I want to know if pcbway can print and assemble the device, using the schematics from the pdf and the BOM from the excel...
