I have a project but I don't have a Gerber file. I don't have a professional program for Gerber files. I have a DXP file. Is there any program that converts DXP to Gerber? I use DesingSpark an...
Hello,I have a question related to routing. I want to make a routing program in CAM350 for removing the mill tabs in the manufacturing process. The process should go like this:The machine routs the PC...
I need pcb design to have Hilink ac to dc converter with ESP32s and mini/micro relay (2ch/4ch/8ch) and it should work similar to sonoff 4CH R2 relay. Is it possible to have everything on single pcb so...
Hi!Could you please clarify the following questions:1. What layer in Eagle should I use, to have ENEPIG finish be applied to my board?2. If I don't need Silkscreen, will you aplly Surface Finish e...
Hello,I just saw your amazing prototype lighting device that is based only on solar PV. i was wondering if you do sell any prebuild protoype that which i can purchase as i need it for education purpos...
