I bought a PB-503 that had been used in an electronics teaching school. The school may have altered the pin placement/connections to fit their in-house power, in the 4 wire round power supply plug tha...
Sir, we have 4 layers PCB we are using 0.4mm pitch size, 0.27mm ball size 6x6 BGA IC in our PCB layoutas per PCB capabilities, it suggests that 0.1mm clearance, 0.5mm via (0.2mm drill inside...
I want to place an order for theDIY 1kW Open Source MPPT Solar Charge Controllerby agelo but i want the SMD components like the resistors and ceramic capacitors to be of 1206 instead of 0805 in the ci...
Hello, is it possible to get some images of silkscreen and engraving on sheet metal?Is it possible to get whatever shape of silkscreen/engraving? Thanks and have a nice day, Rémi
Hello,MY question is related to:ElectroPoint4u:Reflow Hotplate Controller.A PID controlled DIY reflow hotplate using an Aluminium PCB to solder SMD components.I am having no trouble getting the contro...
I wanted to purchase the PCB boards that were submitted by a youtube user for a rockman guitar effect pedal project. It was called the Mockman and I think it was the Version 3 or Version 4. If these f...
