[Others] What are the benefits of using a Schmitt trigger for a switch rather than a simple switch?
The circuit design I'm looking at is using a NAND Schmitt trigger and a p channel enhancement mode mosfet with a tactile switch. What are the benefits of that?
16answers
[PCB Prototype] How should I solder these pins, they are tucked under the chip.
I plan to put solder on a corner pad, place the chip and solder that pin, then do the rest one by one. The problem I foresee is that it's almost impossible to see bridged pins because they're ...
[Others] How can I reposition a micro usb port in my project
The casing for my project needs the micro usb port to be in a different position, I'm thinking of using a micro usb extender cable to reposition it, are there any being methods for this? Thanks fo...
9answers
[PCB Prototype] NodeMCU ESP-32 MotorShield
QuantityReferenceValueMount2C1,C7100uFNo3C2,C8,C1047uFNo4C3,C4,C5,C6NCNo1C90.33uFYES1D1RSX101VA-30YESv1PowerPS-85SYES6R1,R2,R3,R4,R5,R610KYES2R7,R80YES1Reg1AMS1117YES1U5DC-JackYES3U7,U10,U112P Termina...
8answers
[PCB Assembly] Is hot air soldering will damage other parts on a PCB?
Hello everyone, I want to remove 6 nixie tubes from my pcb with a hot air soldering, is it safe for the other parts?
[Others] Software help. How can I make 2 loops run at once with Arduino?
Hey everyone, I'm really new in coding, and I want to connect up arduinos to breadboards, LEDs etc. I can easily make one led from eg pin 13 flash, but how can I make one led in pin 13 flash ...
[Others] Can I extend a 4 pin tact switch just using wires?
I want to move it to another position but don't know if it'll work. Any tips for that?
[Others] PCB Design course
Hey guys, I'm currently looking for some more PCB Design experience. Any good classes or websites or resources that anyone know of that would aid in my learning?Thanks
1 ... 82 83 84 85 86 87 88 89 90 91 92 ...
