I'm playing with a 6AR6 design right now running at 400V B+, and am worried about damaging the 300v max input triodes. The operating point is closer to 150, but ofc they will be exposed to the ful...
I am going to make an arduino project which uses a 0.5W speaker, attached to PAM8403(3W amplifier). Can I directly connect them or should I use a resistor?
I am designing a 2-layer PCB, the bottom layer is GND and the top layer is signal and power. The PCB has some sensors and an arduino, also the I2C is used.I'm learning but I am confused about how ...
Hey guys! I'm making a digital power logger and I was wondering if I should add a linear regulator after a switch-mode converter to make the signal less noisy and more stable or should I stick to ...
I have a power supply that provides +36V DC and -36V DC to power the amplifier, but I also need to supply positive and negative voltage to op amps (in an active crossover before the amplifier). Should...
Hello,How should I connect the thermal relieve pad on a CREE led (XPGDPR-L1-0000-00F01) to the center footprint of the aluminium board?How should I make this connection, so that the pad is soldered co...
Здравствуйте.Меня интересует можете ли вы изготавливать импульсные трансформаторы?(Flyback на сердечнике RM10).Если вы знаете кто может, скажите пожалуйста.
