[PCB Prototype] Sw6106 power bank
Can you help me to understand why my pcb works only with usbc connected If leave only the battery it not works ... no 5v as out This is the schema https://pasteboard.co/JChc1yR.png
[Others] How to wire MOSFET transistors when I want to apply a body voltage.
I'm curious where should I apply this voltage? If it will change the threshold voltage, but I can't work out where you would attach a wire to for the body terminal of a MOSFET when they only h...
[PCB Assembly] Part source,
Hi,If I would like to make a PCB assembly with the part : EBC22DCAN-S189from Sullins, is it possible to source the part ? Is the lead time 3 weeks ? What is the unit price for PCBA service ?Thank...
[PCB Prototype] Difference between Via filled with resin and Via filled with copper
What is the difference between Via filled with resin and Via filled with copper?Why I can't select via filled with copper on the website for my PCB?
[PCB Prototype] board design
I attempted to orderESP32 TFT Combiner V1 - Share Project - PCBWayBut received a board in attached photo, Not sure how this happened, just emailed pcbway now. What was this board used for?
[PCB Assembly] SD Wire project
I know you guys have already built some of these:https://git.tizen.org/cgit/tools/testlab/sd-mux/tree/doc/hardware/SDWire Here is a link: https://www.pcbway.com/project/share/SDWire_black.htmlAny...
[Others] How do I read a data if all of the GPIOs are in output mode.
I'm trying to implement an LCD driver. All my pins have been initiated as GPIO output mode. My question is, how do I read a data if all of the GPIOs are in output mode? I mean, we can always chang...
[Others] What is negative resistance exactly means?
What is negative resistance, how is it related to oscillators?In my understanding, it's something to do with decreasing current vs increasing voltage. Is it a necessary condition for oscilla...
[Others] How to achieve energizing a relay with 2 isolated inputs.
I have a 12V relay that I want to be able to energize with two inputs. These inputs might be on individually, or both at the same time. And they must be isolated from each other completely. How can I ...
[PCB Prototype] Otto Pcb Share bom List ?
Hi. Please share bom list for this Otto pcb ? And schematic ? The names of some components are not written on the pcb.
1 ... 84 85 86 87 88 89 90 91 92 93 94 ...
