12answers
[Others] How can I get high audible beeps with buzzer.
Since I've no experience with buzzers, if there are any good ways to choose the right resistor and npn. By the way, I'm using STM32's MCU, supplied with 3V1 to drive a buzzer (GSC4417YA-16...
[PCB Assembly] assemble ttgo tdisplay on another PCB
I have designed a PCB using the ttgo t-display and other components. I have been attaching it to the PCB that you make for me. Can you install this board to my PCB so I don't have to do it later?T...
[Others] Look for the arduino controllable power supply
Hi all, I need to control the speed of a handful of small pumps independently. The speed is directly related to the voltage supplied. I can't really use pwm and the voltage to the pumps must...
[Others] What are those "plus signs"?
How can I avoid adding the three plus signs, shown, that are not part of my design? What are they called? I'm using Ultiboard.
[PCB Prototype] PCB price calculation
How to find out price of PCB depending on BGA pad diameter? Online calculator do not have this parameter.
[Others] Is it possible to exceed inputs whilst keeping concurrency?
I'm building something with an arduino nano which uses 8 buttons (digital) and 8 potentiometers (analog). I would like to add more inputs to the build, but need to be able to use multiple inputs a...
[Others] A question: what is the impedance of a resonating LC circuit?
1. Some people say that capacitive reactance cancels out inductive reactance, so the impedance of an LC circuit is 0 Ω to its resonant frequency (not accounting for wire resistance).2. Others say that...
[PCB Prototype] production of a printed circuit board according to a sample
good afternoon. is it possible to make a copy of a printed circuit board from a ready-made sample? small changes will be required to the finished product.I send the sample in the attached photo.if req...
[PCB Prototype] Micro Via cost
How much does using microvia in my board design at to the manufacturing cost?I don't see micro via as an option in the instant quote process.My board is 6 layers, standard 10cm x 20cm.
1 ... 86 87 88 89 90 91 92 93 94 95 96 ...
