If I route track to the left pad, the right pad along with the portion of track connecting to it disappears.I think I remember doing something in settings and that issue got resolved, but I forgot wer...
This is an LED driver which controls an LED strip with a remote and can change the colors/intensity of the lights. It supplies 12v to the LEDs.I want to know if it is possible to replace the IR receiv...
I'm using an arduino and the value in the analog pin needs to be monitored constantly at all points in the program . I’m aware of using a interrupt pin but it will only work when a pin goes high o...
I have a momentary swith wired to a board which has a short press and a long press function. I only need the short press function and I cannot program out the long press one, so I need a hardware solu...
I am buidling this circuit to amplify a signal from a analog sensor. But for some reason, when I build the circuit on a breadboard I get 0v on the output of U1. The output of U2 works fine, so there i...
Hello,is there any tutorial or guideline how to prepare board design for your manufacturing?I use Eagle for the design but I do not have an experience with cooperation with manufacturersI would like t...
Should I link up these ground signals or leave them?PCB I'm working on has a main board and then smaller secondary boards which contain external components. Everything is isolated and has its own ...
