Hello.How much are the pin2dms 128x32 board without the Led panels ?With Elektronik and shipping to Germany .Thank youI have the LED panels. I just need the&nbs...
I have some DC motors which I need to power and the power supply can handle the motors (I have a beefy 12V 60A output buck converter which is advertised as having "Short Circuit Protection")...
One question I saw:Should the ground plane be placed under components to decrease EM radiation, as (I think) this will increase the parasitic capacitance and limit the signal rate of the circuit?
Hello there, I want to connect a gyrosensor (gy_521 MPU-6050) and a touch sensor (Adafruit MPR121 12-Key Capacitive Touch Sensor) to my nano.I already made a simple mp3 player. I basically want it to ...
Hi, I cant download the schematic, is it possible to allow downloads, i cant read it clearly. If not, do I gain access to it if I order the pcb?Thanks in advance
This adapter is design for a 87C510 DIP28 eprom, but i need the same adapter for a 87PC110 PCC32 eprom !Do you have this adapter or can you make it ?It's the same converter (74HCT573), with same p...
