Dear sir, I am dr. Campanella Michele form Italy. We will start a project of Modulator/Mhz that we use the LMX2306 or LMX2316 IC (SSOP case 20 pin). Weneed 50/100 pieces of pcb adapters from SSOP20 pi...
I am not sure how to do this panelize thing and also can someone tell me what I need to do for the following PCB Attached here or do I need to panelize at all for my pcb. If I have to do anything like...
Hello! I have a question.What types of RGB LED's are used on your 6th anniversary badge?I couldn't find these types of LED's and I wanted some flashing RGB LED's for my project...
I know ways of triggering a single SCR using a microcontroller pin. How would you go about triggering multiple SCRs in series using a microcontroller since only the last SCR cathode is connected to gr...
I was planning on using a wifi socket to control this dehumidifier only to find out it's touch sensitive switch which defaults to off when plugged into power. Have you met this? Any way to bypass ...
