[PCB Prototype] speakersss
Hi, I saw your youtube video and i was just wondering if there was any smaller type of speaker i could use for this project.
[PCB Prototype] EVO128x32 board
EVO128x32 boardThis PCB came assembled? With components?
[Others] Teensy 4.0 to emulate 27c512 eproms.
Do you think that this board is fast enough to emulate a 28dip 8bit eprom chip without any other peripherals, just read the Adress Pins (16 digital inputs), get the data from the Teensy ram and output...
[PCB Prototype] circular track on pcb
hello pcbwayerplease help me with a query. I want to design a circular pcb and so i have some leds and resistors forming circle on the pcb . but while making the tracks i am confused . is it reco...
[Others] For PMSM, how is 'field weakening' achieved?
I don't know how the field is actually weakened. For a PMSM motor for example, how can the field be weakened? Is it done through the phase wires or externally?
[PCB Prototype] Do you ship to Bolivia???
Hello, I have a question, do you ship to Bolivia?? I wan to order a pcb circuit from your compani.
[Others] How to measure capacitance using sensors?
Hi all,I don't understand how the capacitance itself can be measured. The dielectric is non-conductive, so it isn't like more current flows whenever the capacitance increases. So, how is capac...
[Others] Why does Capacitors have high resistance in lower frequency?
When having a capacitive circuit powered by AC, you get higher resistance as the frequency gets lower and lower. Why does that happen?Also, does the same thing happen in AC circuits with no capacitanc...
1 ... 91 92 93 94 95 96 97 98 99 100 101 ...
